Author Topic: what do you want for nothing?  (Read 3397 times)
no bs
on: March 07, 2018, 01:55:41 am
frankenbullet lives with the donor 2016 bullet engine. i gutted the original and have many useful parts for them that need'um. shit-canned the split cases, but pretty much everything else is up for grabs. did i mention free?
Guaire
Reply #1 on: March 07, 2018, 01:50:20 pm
I’ll check part numbers to see if the cylinder head cover is the same on my GT as the 500 Bullet. If so, I could use the cover.
Cheers,
Bill
no bs
Reply #2 on: March 11, 2018, 02:04:27 am
from everything i can see, the rocker covers are the same. the increased bore should not affect the external upper head dimension.
Desi Bike
Reply #3 on: March 13, 2018, 03:07:59 pm
I need a head steady bracket if you have one.
میں نہیں چاہتا کہ ایک اچار
no bs
Reply #4 on: March 13, 2018, 06:13:38 pm
sorry desi bike, mine broke years ago. made one from 3/16" flat stock.
Reply #5 on: March 13, 2018, 09:28:44 pm
Wow!
That's a pretty severe case of overkill.
A piece of 1/8" cold rolled steel would be easier to work with and it is probably twice as strong as the OEM thing. :)
no bs
Reply #6 on: March 14, 2018, 12:48:39 am
it's what i had at hand; no sign of letting go like the original!
  • Global Moderator
Reply #7 on: March 14, 2018, 04:33:21 am
We used to sell some heavy duty head braces that we had made. The broken ones in the words of Tim Hirdler were "the gift that keeps on giving". Later model ones are better. If you need one make it yourself from heavier stock
www.cyclesidecar.com
Fragman
Reply #8 on: March 14, 2018, 05:33:51 am
Folks could make an adjustable head steady if they be handy shop rats, or they can order one from Hitchcocks. I'll make mine from plate stainless I reckon.
Nothing better than a nice putt on an RE.
It's a serene way to travel at an unhurried pace.
-2013 Classic Maroon-
Desi Bike
Reply #9 on: March 14, 2018, 10:11:52 pm
I guess I'll have to make one up.  Thanks anyway
gavinfdavies
  • Noli Timere Messorem
Reply #10 on: April 05, 2018, 04:22:22 am
Are the two cams available? I've getting some tuning work done on my engine, and would like to try custom grinds on stock cams. Hitchcock cams aren't cheap you see.
gavinfdavies
Reply #11 on: April 05, 2018, 04:23:38 am
Oh, and other timing related bits (followers, rods, etc). Happy to make a donation :)
