Hi fellows!
Here I'm, again, boring you with another set of questions!
I read about people that are worried about checking the lubrication system of the Bullet while running. I've the same fear, after read some horrible stories about lubrication system failure.
I saw some device that owners tell are good to keep an eye on the spot. I wanna talk with you about that, because I don't know if they're helpful or not.
1. Oil Circulation Sight GlassI read about that in this thread
https://forum.classicmotorworks.com/index.php/topic,14842.0.htmlhere there's a video of the device
https://www.youtube.com/watch?v=f0QGZ6_wFEwOthers, reccomend to use a plexiglass tappet cover that allow to see the oil dripping down, proof of a working lubrication.
2. Oil Pressure GaugeI read about that here,
https://forum.classicmotorworks.com/index.php/topic,655.0.html I understood the pressure it's not a good parameter to check, due to the low working pressure of the Bullet Classic Engine.
In this video, you can see this kind of gauge:
https://www.youtube.com/watch?v=dNNPKzxs56E In the comment we have:
"It seems like the pressure gauge location is too close to the pump, and only reading the pump pulses. A oil temp gauge would e helpful too. " I think it's good to know our pumps are working...
3. Oil Temperature GaugeSimple. You can buy one of that device, and fix it like an oil dipstick. Many users said that oil temperature is a much better parameter to check, to build up an idea about the situation. What's the range of operating temperature?
Am I too much worry about that or it's good to mod my bike with one of these device?
