K&N RO-5010 is the correct filter for the C5.
Here's a link to a post I wrote after installing the K&N filter that was made specifically for the Royal Enfields.https://forum.classicmotorworks.com/index.php/topic,12850.msg143219.html#msg143219There are more than one of my comments in the post so read thru the whole thing.The air box on my G5 is a little different than the ones on the C5 and B5 so the filter might work a bit better on them but the basic finding that the K&N was more restrictive than the factory paper filter still leads me to believe they are not all their cracked up to be. (IMO, just having some racing success doesn't mean they did better than a pleated paper filter would have done under the same conditions.)
I don't think they're worth the money is based on my experiences with the flat panel ones on other bikes where they don't fit the lid properly so don't seal well. Have used the cone shaped pod filters on my Ducati, prefer foam Uni Filters. And have seen bikes not running as well as they did with a paper element because the filter had been overdosed on the filter fluid. My 2c, YMMV etc
Thanks, I have read that either will work...the 5010 is probably a better fit.
