No, not using clutch at all.
I went ahead and drained the gear oil box and replaced with new gear oil. Same issue. I guess you could say it feels like the kicker is sliding, not engaging (what I referred to earlier as gummy). You can move it with quite a bit of force but it does not feel normal and net result is still - it does not start.
I also checked and cleaned spark plug.
