Author Topic: Front Wheel Axle Removal  (Read 643 times)
on: January 26, 2018, 03:46:56 pm
How does the front axle come out on a 58 Connie?  I need to remove it to balance the wheel.  Does the bearing come with it?
grumbern
Reply #1 on: January 27, 2018, 04:13:13 am
Yes, it does! The axle is shaped like this and held by the bearings:
Reply #2 on: January 27, 2018, 06:44:34 am
That's exactly what I was afraid of.  So, I'll have to remove the axle and bearing to balance the wheel.  Ok, thanks.
grumbern
Reply #3 on: January 27, 2018, 08:26:09 am
You can also balance it with the axle installed. Either clamp it between two tips, or place the axle upon a stand. You can even balance it directly in the forks.
Andreas
Reply #4 on: January 27, 2018, 06:43:24 pm
Andreas
Not with the digital spin balancer at work.  The axle has to be removed to mount the wheel to the machine.  It wasn't the easiest task, but I got it tackled after work.  All good to go.  Thanks!
