As someone who converted my 2013 from EFI to a carb, using the Hitchcock's kit, I just have to scratch my head and wonder why someone would want to ruin a perfectly good carbureted bike with EFI. The Enfield is not a modern bike, and IMO should not have all that computer crap on it. I bought mine with the intention of converting it. The carb conversion, along with a smaller lighter non cat exhaust has resulted in a much improved bike. It sounds way better, with a carb you can turn down the idle to where you can here the THUMP. Throttle response is also much improved, it is now crisp and clean, where it used to hesitate when the throttle was whacked open suddenly. EFI really means EPA, and not only is there no benefit to the owner, but performance is not as good, and you are stuck with a lot of expensive failure prone electronics that you can't work on. You can fry the fuel pump just by running out of gas. I still have the EFI parts I removed, including the fuel pump, if anybody needs them.
