thanks all. regulator is attached to the ecu box
here's what I can tell you about the bike in the first 50 miles
first off I was have a great deal of trouble starting it. it was just cranking away and failing to kick over. at times I was actually wondering if it would go or not
I read on the indian forum they don't like a full fuel tank so I removed roughly 2 litres - fully charged the battery - and fitted an ngkbpr6es plug....no difference! still hard to start!
with all my bikes I've had the habit of just applying a slight bit of throttle just as I hit the starter - all had sports muffler on the start ups. i'd been doing the same with this one.
by accident my hand slipped off the throttle on start up and it started immediately. after that I started the bike several times without throttle and today after an overnight sit - it started immediately and idled away perfectly on one press of the starter button. maybe the ngk helped here too
now I have not ridden it over 40 mph but I can tell you it is a very very smooth bike to ride compared to previous jobs and is running the upgraded fueling map in the ecu. best news non of that jerky type of riding experience just a good clean smooth ride
vibration in the bike so far appears to be very low too. but the big news I think is how well they have smoothed out or refined the fueling to the motor - plus it actually feels a bit quicker in standard form
