With temperatures in the 70's, I opened the garage door and fired up my GT for the first time in a couple of months. ( Had foot surgery and Dr says I still shouldn't ride ). After several minutes of idling nicely it unexpectedly died and wouldn't restart. All indications, or lack of, seemed normal. Got the plug wrench to check for spark. Reached down and found the high tension lead had come out of the NGK plug cap. "Screwed" it back in and all is well again. Time to replace the HT lead. Question is : does the ht lead unscrew from the coil, or does the coil have to be replaced? Thanks
