Yes, very lucky. It could have easily knocked a hole in the piston, let metal fall down into the crankcase, and possibly even bent the rod. I think I would replace the piston. I have no idea how thick the piston is, or the quality of metal it is made out of.
I did make it past 10,000 miles. Not without some issues, but nothing with the engine. It still runs great. I also replaced the long heavy cat con muffler with a much smaller, lighter, and louder one with a similar look. And, I replaced the EFI with an Amal carb. I'm so glad that was possible, not to mention cheap and easy, because I am not a fan of EFI.
I don't ride mine in a "spirited" manner, it has never been above 60 mph, and most of the time I ride it at 55 mph. I like to take it out on the highway and ride it 200 miles or more at a steady 55. It is a very relaxing ride. The seats in many expensive cars now come with built in vibrators. Not necessary on the RE. And the sound of the long stroke single at low rpm through a less restrictive exhaust is pure music.
