And I quote...
" Assemble exhaust and inlet hydraulic tappets into Crank case RH lubricate and check free up upward and downward movement inside Crank case RH tunnel "
No mention about lining up the oil holes !? ^^^
"CAUTION :"
" Please ensure the roller should be facing downwards during assembly "
And that's IT as far as I see it in the book . Well .... no shyte Sherlock ?! The roller rides on the Cam and the push rod tip ?!
Hahahaha ! And BTW, you CAN'T install the lifter's in there prospective bores upside down ... or tunnels as the call it , because you wont be able to fit in the anti-rotation pins in the crank case.... Duh ! They call those anti-rotation pins " needle roller pins " Ummmmmmm....... ?? Well I guess that IS what they are made of ?! But they certainly don't roll, and can be quite a bitch to pull out. They locate the lifter in the bore correctly, so as not to allow the roller on the lifter from turning sideways and wiping out your cam ! Geez....
There are "Flats" machined onto the top of the lifter. The anti-rotation pin slides in , from the inside of the crank case , and up against that FLAT on top of the lifter... and it holds it there in place, to keep it from... ROTATING in the bore ! The lifter has these flats on both side at the top. BUT... there is only ONE oil hole on the lifter. When the lifter is installed, the oil hole on the lifter should face the oil passage in the lifter bore. It's easy to get this wrong and put it in back words or turned 180 degree's the wrong way around if not paying attention ....
If this were to be the case and it put in wrong ? I could see a noisy lifter at idle ..... not getting very much oil pressure in there at those low RPM's with the oil hole in the lifter pointed AWAY from it's feed source....
