Author Topic: Chain alignment tool  (Read 1311 times)
Richard230
on: November 08, 2017, 10:45:44 am
Here is a link showing how to use the Motion Pro chain alignment tool.  I have one, it works great and is very easy to use:  https://www.bikebandit.com/blog/post/video-how-to-use-a-chain-alignment-tool-at-bikebandit-com
hpwaco
Reply #1 on: November 08, 2017, 03:24:06 pm
Cycle Gear also offers similar chain align tools.
  • Global Moderator
Reply #2 on: November 08, 2017, 06:15:05 pm
Actually RE made/makes one. I may have the only one in existance but I bet you could still get one from Royal Enfield of Ft. Worth. Tim is working there on a full time basis and no one (and I mean no one) knows more about RE parts and part number history than he does
www.cyclesidecar.com
solg
  • /Users/solgualtieri/Desktop/165532_489778052839_61
Reply #3 on: November 09, 2017, 07:11:22 am
I have a 2008 Iron barrel. the drum brake plate covers must of the sprocket. Leaving not much more than the sprocket teeth showing. Will this gadget still work on the 2008?
The computer can't tell you the emotional story. It can give you the exact mathematical design, but what's missing is the eyebrows. FZ
Richard230
Reply #4 on: November 09, 2017, 08:15:05 am
While I haven't tried it out on my 2011 B5, it looks like it would work once the chain guard is removed.
REpozer
  • Royal Enfield Let the good times roll.
Reply #5 on: November 09, 2017, 02:34:40 pm
Not a bad looking tool for the price.
I’ve successfully used a string that was tied between heavy boxes and stretched out  along the front and rear wheels.
After I adjusted the rear wheel chain snails, I used a paint pen to mark the snails for even use next time .
REA # 84 ( the first time)
hpwaco
Reply #6 on: November 20, 2017, 10:54:47 am
Nov/Dec issue of MOTORCYCLIST has a review of the Motion Pro chain alignment tool.
portisheadric
Reply #7 on: November 20, 2017, 11:11:40 am
If your sprocket teeth clear the inside face of the inner and outer chain plates when you spin the rear wheel backwards, you can be pretty confident your chain is accurately aligned.
'18 Bonneville T120. Green & White
Carlsberg Wordsworth
Reply #8 on: November 20, 2017, 01:08:57 pm
That's how I determine mine too portishedric.
I might fashion one up out of a mini g-clamp I have hanging around for the fun of it. Drill a whole and a bit of rod and job done.
gizzo
  • Live slow, die whenever
Reply #9 on: December 05, 2017, 04:06:41 am
I made one a while back from a little block of wood and a small aluminium tube. Works great. I have the motion pro tool as well, but it won't fit the CGT. Works great on my other bikes tho. recomend it.
simon from south Australia
Continental GT
Pantah
Monster
DR250
Honda C90
TRX850
DRZ400SM
ERC
Reply #10 on: January 10, 2018, 03:12:10 pm
They've had them out for years mines blue.  lol
