Greetings,
In regard to chain tension (rear), I believe the Snidal manual states that you should have about 2" of slack when seated on the bike.
I interpret that to mean, "while you're seated, have your friend grab the chain at its droopiest section. It should be able to freely move 2 vertical inches."
I find this to be a very loose chain. A few years ago I lost a few teeth on the stock rear sprocket due to chain looseness. Maybe it got a bit looser than recommended, but I've been sensitive to this since replacing the sprocket.
I have the stock rear suspension installed (at maximum preload), and it's not uncommon for me to ride two-up with the Misses. As you all know, the stock shocks are garbage, and with 2-up it's not unheard of for us to bottom-out. Even when riding solo (spirited) I've had a few rear bottoms-out.
This got me thinking... Yes, I know a big recommendation is to replace the rear shocks, but at the moment I can't justify the cost. I also do not think that will answer my following question. At the moment I'm interested in chain tension:
Have any of you considered installing a spring-loaded chain-tensioner? There are lots of aftermarket MX ones, and some more expensive 'custom cruiser' tensioners as well.
My thought is that a chain tensioner would help prevent chain-slippage on the rear sprocket and teeth breakage. It would also flex when needed for the unfortunate reality of the occasional bottom-out, thus preventing undue stress on an over-tight chain.
Am I crazy? Are there any other crazies out there?
Cheers,
Chuck
