To all
Because of the intermittent nature of this problem it has been difficult to recreate and diagnose, but here I am finally with a positive update. I pulled out the ECU and when I rotated its harness slightly I caught a glimpse of copper through a hole worn through the black tape, presumably the result of vibration and unintended contact with a bracket. I peeled back the black tape to reveal a black wire and a white wire with a black strip both had a bit of their insulation missing, exposing the wire which was apparently giving a ground fault I then made sure nothing exposed was touching and turned on the key. The bike primed perfectly. You guys really know your stuff. It's just as you said. BRAVO & THANK YOU ALL!
So I'll surely need to wrap the harness better to protect against future abrasion, but how best to repair these very small bits of missing insulation which are the width of a pencil lead? Would a liquid brush-on insulation suffice for the repair? It's just the insulation. The wire is not affected. Thanks again to all.
Regards,
Kevin Daly
