You are not going bonker's Arizoni. Yes the originals were leading axle/18" wheel. The 2011 introduced the straight fork/19" combo, er.... I think.
Ah, I think it was gashousegorilla that thought he's going bonkers.
Up until now, I've been quiet.
I stayed out of this because I own a 2011 G5 and that model never had a instability problem.
My 2011 G5 has the axle displaced ahead of the center of the fork downtubes.
The front forks with the axle displaced forward of the downtubes centerline dates back to some of the first hydraulic forks made by Royal Enfield starting with the 1947 Model G and Model J.
The leading or offset axle continued thru the entire Bullet production until it ended in 1964. Needless to say, the 1955 based Indian production also used the leading axle design for all of the Bullets it produced up until the change was made to fix the new UCE C5 Bullets problem.
I suspect some of the problem here is there are several ways of talking about this "leading" design.
There is the offset axle with the axle ahead of the center of the downtubes and there is the axle location relative to the point on the ground where a line thru the steering head bearings centerlines meets the tarmac.
I think most of us are thinking of the relation to the downtubes and Kevin is talking about the point on the ground made from the steering head bearings centers.
That point on the ground has a lot to do with how the motorcycle handles and its stability.
Having the axle in line with or ahead of or even behind the actual downtubes has much less of an effect. If you stop and think about it, the old BMW Earles Fork didn't even have real downtubes but it did have that point on the ground created by the tarmac and the center of the steering head bearings.
Anyway, now that I've bored over half of you, lets get back to the discussion.
