Maybe everyone here already knows about this, but I'm going to take a chance that one or two Bulleteers will be helped by this. This tale of woe applies only to bikes that get kick started regularly. I don't think this would happen while electric starting. (?)
As we are all aware, the Bullet 500 has a tendency to spit back through the carb sometimes. You know, it's that time when the bike kicks you back and sends all its internals rotating backwards. Usually happens when you're trying to impress friends with what a nice bike the RE is.
When the spit back occurs, pressure is built up in the intake manifold. Most of the time this just results in some noise and maybe some smoke coming out the air filter housing. But sometimes, the results of the spit back can be the moving of the carb out of its little rubber manifold.
My Bullet had been running fine but the idle had raised itself a little bit. That should have clued me in to look for an air leak right away, but it didn't. Then, as I was kick starting the bike - it spat back at me. The following kicks produced nothing, nada, zip!
A quick glance in between expletives showed me a carburetor that was no longer plugged into its rubber mount. I quickly reseated the carb in its proper position and started the bike. I believe the slightly lean condition causing the idle to raise was caused by an unseated carb which finally came all the way loose with that last explosion.
So what did I learn from this episode??? Knowing me, probably nothing. But you may have determined by now that checking to see your carb is still plugged in after your bike shows its evil temper by spitting back at you.
My real concern here is that people may have their carbs sitting half in and half out causing a lean condition while cruising along the blacktop at 55+ and coming to a stop after holing a piston. Just sayin'.
