Hi,
I have stupid questions, but I ask it here anyway so it might help others next time
I am planning to change the chain and sprockets:
1. Changing the front sprocket requires to remove the crankcase cover, correct ?
2. If so, I guess there is oil in it, correct ?
3. If so, I guess it is recommended to change the gasket, correct ?
Thanks
1. Yes. Just a heads up, make sure to loosen every bolt and the cover should fall off with slight persuasion unless a sealant was used on the gasket(you don't need it). If the cover doesn't come off with light force, you missed a bolt(s). Also, I kept the bolts in the cover but when I pressed the cover back on for assembly some of the bolts fell out. I found out the bolts are slightly different lengths which took a few minutes of wrenching determining the correct positions which isn't difficult but costs precious time and patience.
2. Yes- I did mine with a corresponding oil change, "two birds with one stone" but if you can put the oil in a clean container then it's not terrible putting that back in.
3. Mine was intact and in really great shape at 2500 miles but it did tear when I was changing the sprocket. I figured I would need a new gasket and I ordered two along with my sprocket just in case I got overzealous.
Here's a link to converting the GT to a 520 chain and sprockets. If I could go back I probably would of went a little more bland with the sprockets but I'm still happy with the modification.
https://forum.classicmotorworks.com/index.php/topic,23085.msg289346.html#msg289346P.S. after looking at the link again, I forgot how much of a pain in the ass the rear wheel can be to install. That first time I removed that I probably spent thirty to forty minutes trying to get that back in place. Now, maybe ten minutes with a rubber mallet and I'm good.
