As the title says: It died on the road, and now wont start. This is what happened: Was in 4th gear, somewhere between 5500-6000 rpm (the needle fluctuates so much at that point its hard to tell). So, I noticed I was beginning to lose power, and had suddenly slowed down to about 60 mph. The engine was skipping the thumping....Foolishly I tried to give more gas and kept at it for a few seconds. No luck. It continued to slow down with real loud popping in the exhaust, and came to a halt. My buddy riding behind me saw sparks/flames shooting out the exhaust. Trailer it home from there.
Testing so far:
1. Fresh gas, carb clean
2. Battery at 13.2 V
3. compression : 120 psi (Ace kit)
4. sparks on kicking
Does not start. I would like to test the coil (bosch blue coil) and the ignition system: Boyer. Where do I start?
