Thanks Tom.
The samrat adjustable spindles, as listed on Mr. H's website, specify they are only to be used on iron barrel engines up to 2005.
http://www.hitchcocksmotorcycles.com/accessory-engine-timingside(see 'adjustable cam spindles' by scrolling down). Mine is a 2008 engine. I suspect someone we both know well has fitted said aftermarket spindles to these 2008 engine cases.
Interestingly, the OE issued cam spindles are listed in the parts book for a 2004 'Sixty Five' model, in standard bore, .003 or .006 oversize, as you have suggested to get.
Note these are also stated to be used only on engines up to 2005.
http://www.hitchcocksmotorcycles.com/partsbooks/pages/4817/Crank_Casesee number 12.
So what gives, are iron barrel engines from 2005 up supposed to use Electra X/AVL cam spindles, or something like that?
Thanks for the offer to let the shop take a look, but I'd like to try my hand first before farming it out.
I am thinking of some of the heat/oil resistant epoxy, that I can cold weld in to place, and sand down as is needed for clearance of the cams rotation.
Good or bad idea?
The main problem is that the 'flats' on the spindles don't reach to the corresponding 'flats' on the engine cases.
Maybe I can bridge the gap between the two with the epoxy.
As I said the spindles have zero 'rocking' in their bores, and can be frozen in place free from rotation with just a little bit of heat applied to the cases.
Or I could get the correct spindles, if I knew what to get. Would probably get them in standard bore size.
Any other thoughts? Bullet Whisperer?
