The other trick they play is blowing the fuse on the fuel pump or the pump connector simply falling off leaving you with gravity feed. Check you can hear the pump, it should have enough suck to clear the breather.
The oem fuel hose is genuine rubbish, mine dissolved in petrol but cost pennies to replace with real petrol hose. Jubilee clips are not for petrol hoses, the small ones do not close circular, hence they leak. Proper petrol hose clamps (stainless 720° with a nut and bolt) are cheap too.
Removing the hose required removing the Jubilee clip out of the way and then gripping the hose with gas nut pliers and turning the hose to break the seal, then pushing it off from its end. The gooey mess oem hose just slipped off, the pukka petrol hose went on easily with my fingers but wanted some brute force to get it off again, they need pushing from the end to compress them and open the hole, if you pull they stretch and close the hole.
