All,
I'm working on a 2005 with an ACE air canister and a Goldie silencer. It's been giving me carb troubles for a while now so it's time to replace. I'd absolutely love to put an AMAL on the bull, but with how often I ride it, I'd like some reliability.
Looks like Mikuni is the way to go. But, I don't understand the difference between the performance of the flat slide and round slide models. Can someone explain. The other issue I'm having is the lack of space between the Mikarb I've got now and the bottom of the gas tank. There's not much clearance and it seems to be stressing the throttle cable where it enters the carb. Any fixes for that? Or is that out of the ordinary?
Thanks for all the help so far.
I'm very happy with the TM32 I installed on my '08 AVL after the ACE headwork in 2014. It was a season long learning experience, but I soon understood the little bastard in detail and can remove and reinstall it in my sleep now. Much tweaking can be done without removing it, but not everything. I can't give you tuning advice for your particular engine because my engine is far from stock (totally reshaped comb chamber, better flow, huge valves, 9.8:1 comp) and I had to learn what my engine wanted from the carb by lots of experimentation. My only "big" problem is with the spring and top cover when removing and replacing it is necessary as in playing with needle types and height adjustments, but that's to do more with my hands and wrists (they don't do what I need them to do any more) than the actual difficulty level. No problem for people with no pain issues.
You can get any shape throttle cable entry tube you might need (straight, 90 or 45 degree) from SUDCO. I've got perfect, smooth action with the straight one by meticulous tweaking, cable routing, etc.. (I'm a meticulous tweaker by nature
Remove the hot tube (if you have one) from the muffler end of your header pipe if you haven't already; it's very restrictive. You don't want to go through dialing in a TM32 (or any other) with it in there and then do it all over again when you realize you need to remove it to get the most out of what you've already done (carb, exhaust, air intake).
Radiator hose is good for your transition tubes from head to carb and from carb to canister.
