Then there's the SB/GHG UCE dome top piston... I can't explain the squish characteristics but it will cause the earth to shake beneath you!
On one occasion, as I was passing a young lady by the curb, she just about jumped right out of her yoga pants! When I checked my mirror she was still in the air... It was quite impressive.
LOL ! Yeah...Tumble, swirl and squish. Plenty of that !
Short addition to Arizoni's 28 hp note. I see it dyno's at the rear wheel at 18 horse.
Inertia Dyno's kinda suck... especially when they plunk in an " average gear ratio" when doing a test. BUT, they are pretty much the "accepted" method for at the wheel numbers on a bike. Real world, I bet they are doing a little better then 18-20 at the wheel.
Coincidence with the claimed 28 HP ....I don't know ? But here is a very near to stock bike not using an inertia Dyno and it is also "at the wheel". Just a slip on muffler, o2 removed and intake cam rephrased. AND running too rich, so there is more power to be made there ... another horse or two maybe ? Running regular old 87 ethanol laced pump piss... A slightly higher BTU content WOULD be nice.
The cam re-phase is just shifting the power up a bit in the RPM range.... lined up straight on the marks, the power would come in with similar number's , but at a lower rpm me thinks.
