I was cruising past a tractor supply a little while ago , so I stopped in and grabbed one for ten bucks . Looks damn near perfect ? I'll measure it up when I get home ...
The Ingersoll Rand job is..
4 1/4 in. OD, 3 in. ID, and 2 3/8 in. tall. over the rubber ends. It's about 13 in. around , and has the same filter surface area on the outer sides as the stock filter.... which is 1 5/8 in. wide. So about 21 square inches of exposed filtering area in the box. ...Plenty I think. It would work perfect !......
BUT , because the Compressor filter is not as tall as the stock one. You would need more threads on the threaded post in the C-5 air box, which holds the plate on top of the filter. Or ... replace that threaded stud or post with a new bolt that would allow you to thread the nut down onto the plate deeper, so a good seal could be made against the filter. Very do-able I think ? If a full threaded bolt were to be put in there in place of the stock post, one could use either the stock filter, or one of these filters when needed. I'll post pictures if you need them..
