I've found the CR to be about 8.5 in the stock GT engine. Fixing the squish gave a CR of 9.0.
GHG: Maybe the deck hight is different on a 500 but on the 535 removing gaskets is just not enough. Could be another improvement RE did to that engine besides lightening the crank.
I have found generally from different 500 motors that I measured, the compression ratio is in the 7.75- 1 area. Unlike their advertised 8.5-1 , where I assume all they are factoring in is cylinder volume and combustion chamber volume. Discounting deck height, dish volume, gasket thickness and etc.
I does sound like the deck height IS different in the GT's ... you guys have been inside them. And certainly not the only bike or motor out there with a piston outside of the " optimal hot rod Chevy 450 four barrel squish band".
The 500's are generally a little south or north of 1 Mil down in the hole , BEFORE the stock head gasket and head goes on. Removing a section or two of head gasket may not be "enough" on the GT.... If "ALL" your concerned about is getting a higher compression ratio and tightening up that squish band. Discounting or giving up things like chamber volume and flow and etc. You just want... In my humble opinion, and without over thinking it.... an area small enough to force out the trapped reactive mix at high speed which is caught under and in between the head and the edge of the piston... And that's it. I err on the side of a little "loose" in that regard, over a little tight in that regard. A little too "Tight" , and instead of that reactive mix being forced out from under things... It may crack off and burn under there instead. I and I really don't think there is any ONE fixed measurement that works for ALL motors and all combustion chamber designs. All things have to be factored in I believe. Your piston crown is going to effect the burn.. your chamber shape is going to effect the burn and etc.
Correct me if I'm wrong... I think I remember in your case ? You adjusted your deck height at the barrel ?.. increasing your compression ratio by doing so. AND you also un-shrouded your valves, increasing flow AND increasing chamber Volume . Is that correct ? If so, that's pretty damn good thinking.
And I think you got about 25 at the wheel with the customary intake and exhaust mods ? That's pretty good over a stock bike But If so, that is but ONE way to do it I think...
I agree totally with what GHG says. Although I didn,t actually measure the C.R. of the CGT I tuned, I had to shorten the barrel by 1.5mm to get a 1mm squish clearance with a base and head gasket in place, so the C.R. has to be the other side of 9:1, at a guess. What I KNOW, is the C.I. motors in 350 and 500 forms really wake up when they hit 10:1 and I usually retard the inlet cams in these by a whole tooth [18 degrees] and get excellent results, although I fitted the Hitchcock cams to the CGT timed to the marks and it went well enough. Basic unleaded seems to work fine for me.
The only downsides I have spotted with the UCE engines to date is their standard cams seem to have very short timings and the timings are not ideal. Also, there is no crankshaft 'timing pinion' - the gear teeth are cut into the mainshaft, so no 3 way pinions for these and if anything happens to damage those teeth, it will be a full engine strip and a crank job to put it right
B.W.
Good stuff !! Getting your hands dirty, tools and bikes all over the garage, trial and error and getting it out on the road and beating it !
A little sacrificial lamb thing going on with that idler gear aye ? Maybe that is why they decided to go with the eccentric spindles and one less gear to avoid any losses with the extra gear ? OR, they were just being cheap ! LOL ! I'll tell ya... I always set that cam lash slightly loose. SCREW any noise that may arise ! I set those Cams so there is nice and easy, sliding them in and out between all the gears teeth, AND in ALL positions. With JUST a little perceptible... slightest of noise when grabbing the gears trying to shake them.
