A fellow from the neighborhood (not a forum member) has a GT that he has slowly been upgrading for performance (exhaust, K&N, PC-V) he recently added Hitchcocks cams and that's where the trouble started. A lot of noise persuaded him to take it back , and when the side cover finally came off the motor, it was found that a couple of teeth on the exhaust cam had broken off. The cam looked discolored, possibly from heat. ..a lot if heat, as the eccentric adjustment spindle fused itself to the inner stud/perch thingee. I think the cam lash was not properly set IMO . I know there were some bad cams that came out but supposedly that issue was addressed before he bought his cams. At any rate, no one is accepting blame, but RE USA is in contact with him...not sure what will transpire there, as I recently got in this loop when I reached out to help him.
I told him I'd help if his issue wasn't resolved (or as a local shop told him, $800 to CUT the bad spindle off and replace ) so my question for those that have torn that far into the UCE motors, is there a removal tool for the inner spindle? I have seen them for the iron barrel motors, but most sellers do not specifically state "UCE". Hitchcocks has 2 listed, one for iron barrel motors and one for "electra's". Wonder if the Electra one would work on uce spindles? If not, the threads on the end of the spindle for the lock nuts appear to be intact. Would a modified slide hammer pull the spindle out if the case were gently heated ?
Any one ever seen such damage on a cam spindle?
