What is this system? That's what I've been calling a 'relay', and when I said I bridged the solenoid what I did was jump start the bike going hot from the battery to the white end. The green, where I thought I may have isolated the problem, looks like a passive connector. I guess the word 'relay' is a poor choice.
But I've messed up. Can't even kick start right the bike right now.
What I did:
__Disassemble the right housing (kill switch, throttle cable, headlamp toggle, electric starter switch) to see if I went hot from the battery to the switch that'd produce a start. It produced the same result (amperage spike, click).
__Disconnect the wires from that passive connector, thinking there I'd find a short. Went straight to the clear end with both wires. Got the same result.
I don't think my removing that green diode is keeping me from starting the bike. I didn't move the top portion of the housing at all, which contains the kill switch, and I don't believe I've blown the switch because I still get that amperage spike when I try to hit electric start button. I carefully reassembled the housing, and don't see why moving the throttle cable about would keep me from kick starting the bike anyhow.
I did check the spark plug today, and thought I reattached the wire properly. What's my problem? Loose throttle cable? Spark? Did messing about with the wiring to the start button perhaps do something? Do I need to replace this green diode?
I'm hopless
