Author Topic: AVL Clutch/Neutral Light/Starter Relay Switch Circuit  (Read 7924 times)
      Would someone please very clearly explain to me how this frigging clutch switch bullshit switch works and why I can't do away with it?
       I want to be able to start the engine electrically in neutral without holding the clutch in IF I! CHOOSE to. Just like I turn the head light on when I! want it on.
      The switch has a Black wire from the Starter relay, a Brown wire from the Neutral Light/Neutral Switch wire and a Green to Ground.
       It looks like when you pull the lever it closes the Black wire's connection to Ground (the Green wire) allowing the Relay and Starter to do their thing.
      Or am I all wrong and the clutch lever only has to be pulled if the Neutral Switch is Open?, IOW in gear. If so, I've just been suffering under a miscontrusionment all these years.
« Last Edit: May 30, 2017, 12:05:12 am by tooseevee »
Reply #1 on: May 30, 2017, 01:10:55 pm
            Never mind. I found it all online and in the back pages of the forum. And Youtube.
Reply #2 on: May 30, 2017, 02:37:14 pm
Glad you found the info you were after!  I didn't want to chime in with no helpful answers.  But while we're here...
What did you discover?  My 2011 UCE B5 does start in neutral without holding the clutch in - the clutch switch only comes into play if the bike is in gear when you press the magic button...
Reply #3 on: May 30, 2017, 05:31:08 pm
           Yes. As you state is correct for the AVL also.
            The Neutral "switch" is just a path to Ground for the Starter Relay when the gear box is in neutral.
             When the gear box is NOT in neutral, the Clutch Lever Switch provides a path to Ground for the Starter Relay.
             I only use the electric for the first start of the day. From then on it's a one or two kicker. I just got used to pulling the clutch when using the electric because it seemed to start quicker and easier and I forgot I didn't HAVE to.
              I've never solved my cold kick start problem and believe me I have tried every combination and permutation over the years. After years of running various experiments, I'm 99% positive the problem is me. Plus some of it is the almost 10:1 compression from the head work ACE did (Thank you again). I am just not getting enough power out of my kick (when the engine and the oil are cold) to get the inertia to get past the plug driving the piston back down on it's way up. Believe me, I've obsessed and experimented over this for years and I'm sure I'm correct.
       I get instant cold starts with the electric button because the starter easily gets the piston past that troublesome, sprag-killing 2nd spark that seems to come right at the bottom of the kicker stroke (yes, I kick through and hold as far forward as possible and it still Klangs backwards when the plug fires). Once the engine and oil are hot (even really warm) I get easy, one or two kick starts with no sprag-killing KLANG! at the bottom of the kicker stroke like when the engine is stone cold.
        Actually it may be the 1st spark for all I know. All I know for sure is that this particular engine, with the head work, the TM 32 and my weak and wasted 140 pounds, absolutely will not kickstart cold. And it runs like a dream out on the road and I love it. Just the 1st stage headwork that Ace did made it a totally different bike from stock (Thanks again). Add the carb and open exhaust and now the Pertronix coil and it's just a great bike. I really wish I could kick start it cold and Never use the electric, but I just gave up on it last year. I did NOT want to keep jeopardizing the sprag by thinking it might still be a dialing in problem and continuing to get the Klang no matter WHAT I tried to tweak.
« Last Edit: May 30, 2017, 05:34:06 pm by tooseevee »
Reply #4 on: June 15, 2017, 12:31:09 am
       I think I've done away with all present and future problems with my Minda starter button not making positive reliable contact. At Arizoni's suggestion, I installed a regular 5-pin Bosch-type relay (Tyco) between the starter button and the big starter relay in the left sidecase. At the barest touch of the starter button now the starter spins its little Denso heart out every time, no hesitation, no wiggling, no praying  :) :)
         Before and After pictures below.
         The Main circuit breaker is at the top.
         The White connector goes to the stop light switch. The factory plastic, glass-fuse, holder now holds spare 10 amp blade-type fuses for the ECU/TCI fuse holder which is up under the seat.
          I've got a complete Minda right side switchset on a shelf now that I'll probably never need.  I'm almost getting to the point where I can really trust this great little bike 100% and what a long strange trip it's been. Now, if I was 30 years younger .... Ah, well. I had my times :) :) ;)
          I know. I know  :) I shoulda made the hot wire from the little relay to the big one Red. Best laid plans.....
« Last Edit: June 15, 2017, 12:34:11 am by tooseevee »
Adrian II
Reply #5 on: June 15, 2017, 11:15:04 am
This seems to be an excellent mod for any E/S Bullet, whether C.I., AVL/Electra-X or EFI. Glad it helps keep you on the road where you want to be.
The neutral light swith on my Electra would sometimes go on strike, needing the clutch pulled in in neutral to get the E/S to work.
heloego
  • USA '12 C5, '06 ElectraX
Reply #6 on: June 15, 2017, 12:23:12 pm
+1
   And very neatly done, I might add.  8)
'12 C5 Classic
Reply #7 on: June 15, 2017, 07:21:42 pm
2CV
Thanks for crediting me with the idea of adding a relay to your starter solenoid circuit but, I can't take credit for it.
I think Ice was the one who suggested it.
Glad to hear the new relay is doing its job and everything is working.
Well, maybe not everything but, your legs will recover from the lotus effects sometime within the next 2 weeks.  ;D ;D
Reply #8 on: June 15, 2017, 09:53:11 pm
2CV
              Oh, sh*t - Y'er right. Sorry, Ice. Please don't let this come between us and keep those good suggestions coming  :) :D :)
Reply #9 on: June 16, 2017, 04:58:57 am
Well I can't take credit for the idea either.
 If you ever worked on a Dodge cars or trucks made from the early sixties to the late eighties you will recognize the concept.  ;)
Reply #10 on: June 16, 2017, 01:01:34 pm
           I know you didn't invent the relay, but you can take credit for giving ME the idea to add one to my PHD button. Take credit where credit is due  :) and thanks again. The next owner will be happy, too.
            And remember I'm a old dinosaur. I've had my head under hoods since I was 9 years old in 1947 & my mom was trying to keep her '36 Chevy safe from me while at the same time she was teaching me to drive it on the gravel roads and prairies around Cheyenne. I wish I still had the '40 Ford I drove all through high school. My mom helped me buy it before I even had a license. A lot of us in those days were driving long before we were legal.
             Do you remember that the '40 Ford had a starter button on the dash? And they had a steering lock that was similar to a motorcycle fork lock.
             Sorry. I blabber too much :-[ :-[
Reply #11 on: June 21, 2017, 05:49:52 pm
            During a break from grass mowing (it's been grey and wet here for daze and today the sun is out), I made that wire Red. I'm much happier now and can stop thinking about it  :) :) ;D ::)
             Sometimes being detail oriented can be a curse, but it's what I do  ;) ;)
Dodd
Reply #12 on: September 09, 2017, 12:13:41 am
Tidy job mate.
Will you stick a pic up of the other side?
Interested to see the how you've enclosed the battery.
Reply #13 on: September 10, 2017, 01:25:24 pm
Tidy job mate.
           I just now noticed your post (8:00AM Sunday). I'll get a shot of the battery side over the morning and post it.
           Thanks for asking. There is less and less AVL traffic as the years pass.
« Last Edit: September 10, 2017, 01:29:32 pm by tooseevee »
Reply #14 on: September 10, 2017, 03:16:00 pm
            Here's a picture of the battery in the right side sidecase. It's an MB5.5U size (the picture is a bit fuzzy - don't know why). This battery will give many electric starts if necessary although I kickstart just about all the time.
             And yes, it is well protected from shorting out on the cover by leather and pads of hard closed-cell foam which press the battery inboard and hold it steady when the cover is closed.
              And referencing my post of May 30 below: I DID solve my cold kick start problem totally. After many years of f**king around trying everything possible with no luck, I finally came to my senses and switched to Champion plugs. For some reason this engine just did not like the NKGs I've been using since day one while chasing this problem. I now have easy cold kick starts and reliable electric starts if I want. I totally trust this engine to start now both ways every time after many years of trying everything under the sun.  And I'm amazed that after years of chasing this problem (May 2014) and hearing that hated sprag klank! time after time, it still seems to be pretty much OK and there were no small bits of metal in the bottom of the primary last time I had the cover off (around Thanksgiving 2016).
           What I'd really like for Christmas is an exhaust gas analyzer so I could actually see what the mixture screw is doing. I still get no absolute indication when I tweak it; I only know it starts fine and runs miraculously well out on the road.
            The other thing I wish I could cure is the first 10 or 15 seconds of starting cold when if you DARE touch the throttle it will die, but it feels as if you MUST rev it a bit or it will die. So once in a while it is STILL tricky to keep running that first 15 seconds after which you can just walk away and it will tick over happily. It's very strange.
              But most times now overall it is a very easy starter compared to the years before of NO WAY would it kick start first thing on any given day.
               I've wished I lived down the lane from Bullet Whisperer a thousand times since 2014. Champion plug immediately like magic solved the problem I've been tearing my hair out over.
