Also, there were 2 different Big Head variants, regarding port sizes.
The US market Fury cylinder head had a 1.5" Amal GP carb and 2.5" center stud holes, same as the DBD34 BSA Gold Star, while the vanilla big head Bullet (for the UK market) used 2" center studs and a 1
3/
16" Amal Monobloc carb.
New GP carbs cost big bucks and aren't the best idea if you want to put something together to use on the street. If a big carb to match your Big Head is part of the plan, think Amal 38mm Mk2, Mikuni VM38 or Dell'Orto PHM38, possibly 36mm versions of the Amal and Mikuni or a Dell'Orto PHF36, which some reckon give sweeter all-round performance than their 38mm counterparts.
You might also find this link helpful, these guys have considerable experience of racing Enfields on the dirt:
http://enfieldracing.com/page/28582-EnfieldMy NotaFury project uses one of the Hitchcock replica big heads with the smaller inlet opened out to Fury spec and the carb stud centers plugged and re-drilled/re-tapped to suit. Hitchcocks' produced replicas in both variants from the same batch of castings, I understand the Redditch factory had done the same.
