Well, I'm up to 230 main jet now and in general the bikes runs great, starts on first kick or push of button, has good accelleration, lots of power. It pops a little on decelleration. I have absolutely no color on the plugs - bright white insulater and grey metal electrode. I am paranoid about lean running since every manual I look at has a big warning sign about it. I ordered a richer slide (2.5), richer main jets (240 and 250), a 108 needle jet, and a richer needle taper. I guess I'll keep jetting it richer until I get some color or it seems to have less performance. I did seat the float needle jet a bit lower, so that the bowl filled up a bit fuller, which seems to smooth it out and add a bit of power, but still no plug color.
I also confirmed good fuel flow from petcock and no leaking around manifold.
Matt, do you know what size needle jet and main jet that you are running?
