Since doing the LH to RH changeover, my gearbox is still doing something a little odd.
I can start the bike and then pop the lever up into first and the wheel will spin. But it doesn't hold well much of the time, dropping back into neutral. Sometimes the neutral light will stay on whether the bike is in first or neutral, or flicker.
Other gears work just dandy.
Suggestions? I just put in a new clutch cable, so that should be OK.
