Sorry, just to clear up an error in my last post, the crankcases are stock 500 AVL apart from the oil level tube and some breather modifications, it was the guides that B.W. modified to fit.
B.W.'s alloy collar actually provides
more lateral support for the guides than the factory AVL set-up. If they were to loosen and start fretting it would be back to the machine shop, so I'm hoping with B.W.'s revision they won't need to be disturbed again in my lifetime. I'm not 65 yet, but it's not that far off.
If a set of AVL tappet guides were to become loose and start fretting it might still be possible to reclaim the crankcases by boring out to take the C.I. Bullet tappet guides on their standard outside diameter.
Looking at some of the Indian C.I. tappet and guide sets available I notice there are two different designs, the "classic" and a second option which is actually has the same shape of tappet guide as the AVL.
Copyright of the photo seems to rest with
ClassicSpareParts and
VintageAutoSpares!
http://www.ebay.co.uk/itm/171247980895?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AITThe outside diameter of these guides could be turned down to match the AVL's, but of course this would preclude fitting B.W.'s extra support collar.
Using anything other than the stock AVL exhaust tappet also means losing the AVL valve lifter.
A.
