Took me a little longer, but here are some updates on the braider.
The electrics are installed and working. From left to right you can see the contactor relais, the pwm-pbc that I made and the transformer, providing about 60V. The voltage is rectified and regulated by the pcb and the relais ensures that you have to switch on the machine again, once the power is gone, or emergency stop engaged:
The controll panel. It has two switches. The upper for mains, the lower for switching from cw to ccw rotation, the green button for turning on the machine and an emergency stop button, that shuts off all power to the contactor relais and transformer. If the power is switched on but relais not engaged, the red light is lit, with the machine turned on the green light is lit and red one off:
The turning speed is controlled by a foot pedal, that belongs to my TIG-welder. It has a switch and potentiometer, first one switching a relais on the pcb allowing current to flow to the motor, second one controlling the pulse width provided by the circuit and thus the speed of the motor:
As you can see, the braider has it's own "feet" by now, but it still lacks the full housing and of course the bobbins need to be finished.
So long,
Andreas
