Some may disagree but I think soldering wiring on a motorcycle is asking for trouble.
In its newly made condition, copper wire is in its soft, annealed condition. It bends easily and is quite resistant to vibration.
If left alone, the annealed copper will stay soft and flexible.
Copper does have one interesting property that many aren't aware of.
If it is bent, it starts to harden. If bent back and forth repeatedly, it hardens even more.
Hard things not only resist bending but they are brittle and when subjected to more bending they break due to fatigue.
Getting back to soldering, although it creates an excellent electrical bond, the solder on the wire forms a stiff, hard to bend area that stops abruptly precisely where the solder ends.
If the wire is subjected to vibration it will be forced to move back and forth a small amount at a high rate of speed.
The soft unsoldered wire will "go with the flow" but where it meets the soldered area which won't bend, the copper wire will do all of the bending.
That will harden the wire at that point and as I mentioned, the hardened wire will become brittle and break.
No, this breaking won't happen immediately but it can happen surprisingly soon after the joint was soldered.
This is one of the prime reasons soldered joints are rarely if ever found in a automotive or motorcycle wiring harness (unless the Indians made it
