That's a fair comment GHG, without having a look one might be able to modify the existing tensioner as you mention with a spring. I noticed the brand on the chain from the above pics is a Rolon Chain, Don't know what the quality is like?
Ahhhh... what the Hell ? I'm bored and it only takes a few minutes to pull the cover and primary. And this has ben on my mind. Same brand chain between the Bullets and the GT's it appears. "Rolon" stamped on the link. I have been thrashing mine for about ... At least six years now ? MAYBE, a few of the GT guys were unfortunate enough to get ones with a bad swage on a link pin perhaps ?
Looking at this primary.... and providing everything was made or machined correctly at the factory... there ain't a lot in here that would cause much of a mis-alignment. The spacer behind the sprag gear ..IF.. flipped around back words, would only cause a mis-alignment of .75mm on my bike. Do a few of the GT's have a spacer that was machined too thick, causing a mis-alignment ? .... Maybe ?
With the clutch assembled on the main shaft... and the nylock nut and washer tightened down. There is only about two or three exposed threads sticking through that nut. Looks pretty damn close to what Pete has there in his picture ? And that space is determined by a main shaft collar which sits behind the clutch assembly. It sits proud of the case about 1.5 mm. Was that collar thickness machined correctly ? It at least looks like it was in his picture, because of the amount of exposed thread sticking through the nylock nut.
If the nylock nut were to be loose on the end of the main shaft .....
There.. IS .. a decent amount of in and out play on that shaft , with the nut completely removed . BUT... when the nut is in place and tightened down, there is no play. IF.... the nut were to be a little loose ? Not much in and out play would be involved , or mis-alignment , or separation between the clutch stack and the clutch basket/gear. Remember... there is only two or three exposed threads on that shaft and if the nut were to be loose a full turn, we're only talking about a 1 mm here with the tread pitch on that shaft. I would think it would take the nylock nut completely spinning off of the end of that main shaft, to cause any kind of significant play or mis-alignment ?
If the the nylock nut were to spin off the end of the shaft ? It would be caught around and spinning on the push pad shaft.... the push pad/ bearing and cup assembly would bottom out inside the cover on the clutch linkage pin , and prevent the clutch assembly from separating .... Anyways, that's what I'm seeing here.
Some pictures for comparison purposes....
