Author Topic: I maybe crazy...but.  (Read 2544 times)
1Blackwolf1
on: September 13, 2008, 08:50:56 pm
Wondering how much work it is to convert my sled to right hand shift, since we all know the accessories are lacking in instruction.  Also want to find out if the 1 up 4 down pattern works on the newer bullets.  That pattern is more like the old Nortons.  Ideas? ???
Will Morrison
2007 500 Military
2000 Kawasaki Drifter 1500
2000 Victory V92SC
Many, many other toys.
The garage is full.
  • Global Moderator
Reply #1 on: September 13, 2008, 11:22:54 pm
4 speed or 5?
www.cyclesidecar.com
geoffbaker
Reply #2 on: September 14, 2008, 12:44:44 am
I did a LH to RH conversion on my 2000. I also switched the old gearbox over to using gearbox oil instead of grease (all this requires is changing to a sealed bearing) and drilling a breather hole (as described in the Snidal manual).
The instructions for the conversion are fully covered in a special section of Pete Snidal's manual, so that is not a problem.
Took me a weekend, more or less, to make the conversion. With plenty of time beforehand to plan, familiarize myself with the parts and the instructions and read up on how to tips (there were plenty on the forum. You want to be able to heat some of the parts to spitting hot and freeze others).
1Blackwolf1
Reply #3 on: September 14, 2008, 03:40:54 am
  Guess I forgot to specify, 2007 Military 5 speed.  Any suggestions Royal Enfield1?
Will Morrison
2007 500 Military
2000 Victory V92SC
The garage is full.
