Arizoni,
Thanks very much for that walkthrough... I will definitely test that next time I get it running.
Which brings me to my next point.... LOOKS LIKE WE HAVE A WINNER!!!! (or at least we're zeroing in on one)
The gods of motorcycle maintenance were with me today. I rode around for about 5 minutes, and it died at the top of a hill. Wasn't even warmed up yet. Pulser impedance normal (200 ohms +/-), 12.3 volts was getting to the ignition coil via the brown wire, ignition coil primary and secondary impedance was as stated in my previous tests. These readings are slightly higher than the Factory Manual, but only by a few ohms. I wonder if my coil is also slowly on its way out.
Stator impedance was normal (3 yellow wires about 1 ohm impedance between each, in all combinations). So nothing was the obvious culprit. Buttoned it back up, and it started second kick. More justification for my 'intermittent short in wiring' theory.
Rode for fifteen more minutes, and it died at the top of a hill again. This time it was fully warmed up. I noticed that the kickstart pedal was tighter than usual (of course I generally only kickstart when cold). I checked the tappets to make sure it wasn't an over-tight pushrod that was preventing engine compression. Both pushrods were fine, not too tight.
Got out the trusty multimeter. All impedances were identical to before. The only difference this time is that I was only getting between 2 and 3 volts at the brown wire to the ignition coil (should be about 12). That same wire splits off to also power the TCI, so I checked it there as well. Also 2-3 volts. I opened up the headlight casque and with the ignition switch off, there was 11ish volts running into the ignition switch from the battery, which also matched the battery's current voltage at the poles.
Not realizing I could have just poked my multimeter in the 'back' of that multi-wire plug to check voltage coming out of the ignition switch, I also opened up the right-hand control switch module. It read 2-3 volts at each of those wires as well. When it occurred to me to poke the ignition switch in the back, it read the same there too.
I couldn't fire the enfield back up, so I just rolled down the hill for the 8 blocks home. Motorcycle gods be praised for my good fortune of topographic elevation.
I also diagnosed my alleged 'top end clatter'. One of the rear fuel-tank mounting brackets had rusted and broken off at the weld. The metal tab was still attached to the engine mount and frame, and it was violently knocking against the fuel tank at higher RPM's. Removed the tab, and no more 'knock'. Phew!
So back to the electricals, my first instinct was: It's the ignition switch! But on second thought, doesn't the ignition switch just open up the battery circuit to the rest of the bike, which means it could be literally anything in my harness that's creating this voltage drop?
I again tested the battery at the poles, and it was around 13 volts with the key off. I turned the key and it dropped down to 3 volts. NOTE: I just did this test again just now (after the bike has sat for about an hour), and the voltage is now showing 4 volts with the key on.
Am I now stuck going through every little wire to find the component or connector that's causing the voltage drop?
Thanks in advance- I feel like I'm getting close!
Chuck
