Correct.
All the power gains are within the limits of the stock rev limiter under 5500 rpm.
Note that in the attached dyno chart, ALL parts of the Ace billet GT head curves, both torque and hp, are higher everywhere . There is no power sacrificed anywhere in the rpm range with this head. And it all happens below the rev limiter cut off rpm.
However, as Aus.GT points out, there is room to go higher in power and rpm with the use of cams and other mods.At that point, the rev limit on the Power Commander would be increased to 6000 or 6500 rpm, depending on application.
