Hi Jeri,
Have you got a bigger jet from standard as you need one for a K&N or after market exhaust.
Standard appears to be 110, I got sent a 120, I have seen them on ebay upto 130.
I have a new coil on the way, if thats not a fix I don't know what is!
A tip: when changing the condenser, take a bit of time to shape the connector to the shape of the bolt as there is very little room, not much thread showing and its very fiddly on re-assembly.
If you can push and hold the bolt head in place on the back plate, this will give you maximum thread the fiddle the nut back on, and make sure the tag that the nut screws up against is not touching the back plate.
When you have done it turn on the ignition and check that your amp meter flicks, it will save you a lot of time if you got anything back in the wrong order.
