Hi Ken,
Strange thing is it has run fine, then it goes off again, I agree it seems like starvation, or air leak.
First thing was the plug was changed.
To day I stripped the carb, every thing cleaned, checked the 2 plastic tubes for leaks, none, took the manifold off and took out the steel tube and tapped the hole and screwed in a screw with loctite. (proper professional job!
I have a proper blanking nut on the header pipe.
Tank off and flushed, not much crap, but some that's not in there now, fuel tap off and cleaned/checked.
Timing checked, o.k.
Eventually started the bike, reset the carb and run lovely...................until it stopped!
And again...........and again, until I thought I'd give it a run, took it out down one side of the road round the football pitch, fine, got the the top of the other side and pop, bang splutter, just caught it to get me home.
Dealer got onto Watsonians, they are sending up a new condenser, and a 120 jet.
I canceled the offer for a refund, I want this bike, it cant be much of a problem, for some reason, I must be mad, but I love it!!
I will sort it, if the new jet doesn't work, then he will change the carb!
Its not the dealers fault, it would be easier if I lived nearer, he is doing all that he can, and I trust him totally, as I say he offered to refund and pay the carriage back.
I'm pretty sure its not electrical or timing, when it runs right its fine, but for some reason it seems to run out of fuel but the carb bowl is always full when I check.
Strange!
