I posted in the Tech Help section thought I would mention here in the AVL section in case the answer is not as technical as I thought. In a nutshell, my Electra X has been running sweetly, but on the way back from the gas station - with a full tank it just 'died' - as if the ignition had been switched off.
There is plenty of juice in the battery, the negative is earthed nicely to the frame - but, there is
no other power - no starter, no lights, even the green neutral light is off. It's as dead as a dodo! The kill switch was not touched!
What should I be checking in order of obviousness?
