How do you decarbonize the engine?...................one way is to follow the link below.
http://workshopmanual.tripod.com/Another way is that described below by bullet owner "Wild Bill":
First. Take the bike for a hard run, long enough to get it good
and hot.
Second. Pull into your drive and while reving it to about 3 grand
spritz water into carb inlet
Third. Let it cool down completely.
Fourth. Replace plug.
Fifth. Take it for another hard run and blow all the carbon out.
Guarenteed.
According to "Wild Bill", this works is the water soaks into the hot porous carbon
on top of piston. When you take it for the second hard run is
when it turns to steam and blows the carbon loose from the
piston.
I'm not sure I want to try Bill's method on my bike.
Another method is to get a pint of some stuff called "Sea Foam" and run it through the carburettor (I think that the secret formula for "Sea Foam" is diesel fuel, so you could try a bit of diesel instead).
As for me, the fuel I have been using for 13000 miles seems to be clean and I haven't really noticed any coke inside the cylinder or on the head, so I just leave it alone.
