Author Topic: Lowbrow Customs GT Grips  (Read 914 times)
The Old Coot
  • A car moves the body, a motorcycle moves the soul
on: July 16, 2016, 05:56:27 pm
They are almost like the Beston grips CMW carries but are solid rubber. I found out the hard way if you cut the end off a pair of real Beston grips they fall apart and are trashed. Why would I cut the ends off? Bar end mirrors.
Anyway the GT grips are available for 7/8" or 1" bars and shaped like the Beston. I have seen cheap plastic grip that are shiny and hard as a brick but these have that rubber look to them, not shiny. And are solid but not as hard as the plastic ones. That said the are no where near as soft as the Beston grips are.
But for under $20.00 US they are a nice grip if you need to cut the end off otherwise the Beston at CMW would be my choice as they will help dampen the vibration a bit better.
2012 Kawasaki Versys
2015 Royal Enfield C5 black
2008 Bullet ES 5 Iron Barrel
