I believe it's just a flat rubber ring. Cut a section of old inner tube and make a new one, or just use a piece of cardboard from the backer of a notebook. Or an autoparts store has rolls of thick gasket material and cut a ring. Don't get hung up on the material needing to be exactly the same, all youre doing is sealing the cap to the body to prevent air being drawn through. The Mikuni tm uses a paper type gasket. Don't go using goopy stuff!
