Gonna be a LOT of work to do on this, but when I looked at it I nit-picked the hell out of it (fork seals, head gasket, lost locks key, de-comp frozen, Skidmasters barely serviceable, lights not working in speedo, needs new ignition switch, replace all control cables, carb-to-head adapter, new steering, side covers, and tool box locks, New ignition switch, shocks, chain, front and rear sprockets, brake pads/shoes, and some paint.
) so I did get him to come down from his original price. A lot! This guy knows NOTHING about proper maintenance of a bike. I feel sad for his KLR.
It does kick over very nicely and other than the air leaks in the carb-to-intake adapter causing weak response at lower RPM no odd sounds from the engine before, during, or after a ride. I bore scoped the cylinder. Valves, cylinder head, and chamber looked good. Further inspection warranted once I get the head off. Possible I may need to re-thread or add a helicoil to the spark plug hole, but no problem.
Preliminary inspection once I got it home covers just under 2 pages of items needing fixing or replacement, but I did get it as another project, so I'll just be pessimistic and expect to be sinking more $$$ than originally planning.
Wife's good with it, though, so....
