Good morning Gentlemen,
I hope that you're all very well. My Royal Enfield Continental GT (2015) that has only accumulated 550 kilometres has recently been stored for three months due to work commitments around the country. All sound advice on storing the motorcycle was adhered to, this included full servicing prior to storage. I was even lucky enough to have this stored in a room located inside a house which was great. However, when I was preparing the motorcycle for use two days ago I stumbled on a problem when reconnecting the battery.
The battery prior to storage was removed from the motorcycle correctly (negative followed by positive), electrolytes filled, and a trickle charger was connected to the battery every week to ensure the life of the battery was maintained for my return. Please note, preparation of the motorcycle included cleaning the battery, the terminals and ensuring adequate electrolyte levels. When reinstalling the battery, the positive was connected first followed by the negative as per common sense and the user manual. When applying to the negative terminal it sparked quite a lot, I thought this would be normal and continued to screw the negative terminal, however, a small amount of smoke was present and the sparks were quite bad, I immediately removed the negative connection. The black insulation had started to melt due to the heat and this will be viewable and denoted by the red circles on the attachment. My first thoughts were that there must be a short somewhere. Upon inspection it seemed that there was a small portion of live wire exposed (please see right red circle of the attachment). With the negative being disconnected and using electrical tape I reinsulated the wiring hoping that it could have just been a short and the wire could have been touching the frame of the motorcycle causing the short, however, when insulated correctly and reconnecting the negative, it sparked more than the last and burnt the majority of the insulation. Furthermore, it has also damaged the negative terminal from the heat.
Gentlemen, what am I missing? Please inform me that I am doing something simply and stupidly wrong. If I cannot rectify the problem on the forum, I will be sure to take it to my local dealer. Any information would be greatly appreciated.
With optimism,
Mickey
