Got up at 6am, made some coffee and decided to rip the guts out of the left side and put that sprocket in that has been staring at me from my work bench since the first of summer. Let me start with saying I am no mechanic but I am always up for learning a new task and this one seemed to have the makings of some quality shop time(which I love). I don't have alot of wrenching experience, just enough to really botch stuff up, but enthusiasm and doggedness goes a long way.
I cleared some space and set up a clean area for the parts that were sure to accumulate. First I pulled the stator and then the clutch plates. Simple 'nuf. Then I went to pull the rotor. Problem one, how do I stop the motor form turning while I get the damn nut off. Didn't want to jam up the rear end and the kids sitting on the back weren't heavy enough to stop the tire from slipping on the garage floor. So I improvised and used an oil filter wrench with a strip of innertube. Viola, field-expedient rotor holder thingy. Encountered same issue with the clutch basket nut and used same (insert part name here) improvised holder thingy and got the clutch basket off. No pullers needed for either the front sprocket or the rear sprocket/clutch center. Lucky me.
Next came removing the back chain case. The manual says its held on by three countersunk allen head bolts which apparently were installed by king-freakin-kong. Had to break out the air-ratchet to break them free. The manual doesn't say jack about the chain adjuster bolt or the odd little one at the south end of the case but we persevered and figured that out.
A little bump and pull and its off. And there in all its glory is the @#$% sprocket. This diddy was not designed to be quickly swapped out for sure. A couple of taps with a punch and the big nut is loose and off. New sprocket on in less time than it took to make the coffee once it was exposed. Went back together much smoother and hopefully correctly. I buggered up the rubber grommet that seals off the wires from the alternator as they exit the rear case so I will have to get one of those before I button her up and test it out. All in all not too bad, 4 hours start to current state. I made some shims for the stator re installation and that looks pretty simple. Hope this helps someone contemplating taking on this task. Thanks to the guys who gave me the tips on this. Roger
