Hi and welcome, redsox57!
If all you've done is replace the stock torpedo with an after market one, you should be fine. No tuning required, unless you want to get something like the Power Commander or the EJK. You may notice some occasional popping from it until the ECU compensates, but that's about it.
I replaced mine almost right away with a reverse megaphone. Much freer flowing than the 3 stage Cat, and I did get (IMHO) better response when I accelerate.
