AVL should have the type that Dan described.
However, if the tank was replaced with an early type, the thread would be a 1/4" BSP(British Standard Pipe) thread.
Ace, I bought the bike new in fall of '07. It's a Classic AVL, so I would expect it to the the same as the '07/'08 last of the Cast Iron Classics - not sure if the Electra tank had a different fuel bung on the tank. The 1/4" BSP specs look to big:
1/4"BSP specs are: MajDia: 0.5180 - TPI:19 - Pitch: 0.0526"
ok, I'm measuring the left handed threads of the petcock - these are the same as the RT hd threads of the pipe from the tank. (unfortunately the tank is at the shop)
... note, I'm using a cheap plastic template so not super accurate:
... the major dia of the male pipe threads are 29/64 (or 0.453125) & seem to taper to 15/32 (or 0.46875)
I can't find my standard thread template but on my (plastic) mm template it looks dead on 1.0mm pitch (so, ~25.4 threads per inch) so it may be a fine, 26 TPI?
I found Pingel has conversion petcock nuts - just not listed in sizes this small.
any thoughts?
