Reply #9 on: May 13, 2016, 07:27:52 pm
The front axle is bent. Happens all the time. Examine it carefully, the bend will be very slight, but continue that almost indiscernible bend all the way to the top crown and its quite large. Like I said earlier the bend of the axle that causes the misalignment is hard to notice sometimes without a dial indicator. KEVIN, "so very few Enfields have strait frames" ?Really?
« Last Edit: May 15, 2016, 01:27:13 am by cyrusb »
Logged
2005E Fixed and or Replaced: ignition, fenders,chainguard,wires,carb,headlight,seat,tailight,sprockets,chain,shock springs,fork springs, exhaust system, horn,shifter,clutch arm, trafficators,crankcase vent.
