Bare with me folks, I do apologise, but electricity is a very big weakness of mine, it might as well be a black art to me.
I have constantly been going over the tests, because they didn't seem correct. How could I get one set of tests with results with results from the second set of tests.
So I reconnected the red and white wire to the coil, then conducted the tests again with the black and white wire.
With the ignition key turned on, with the kill switch in the not kill position, there is no current in the black and white wire.
With the ignition key turned on, with the kill switch in the kill position, there is current in the black and white wire.
With the ignition key turned off, and the kill switch in the not kill position, there is no current in the black and white wire.
With the ignition key turned off, and the kill switch in the kill position, there is no current in the black and white wire.
I think going from what you said earlier Arizoni, my kill switch is acting as an on off switch as you described. With the ignition on, and when the kill switch is switched on, its dumping the power to the positive terminal on the coil through the black and white wire.
