I take your point but it is worth noting that many cold start devices on carburetor fed motorcycle engines are a quite crude in their effect, e.g. supplementary slides or butterfly valves, not to mention 'tickler' buttons that introduce raw petrol into the induction tract.
My external choking approach gives me docile first firing with a cold engine and I remove the choke within a few seconds. The built in cold start lever, on the other hand, seems much more drastic in effect - the engine shows no signs of life whatsoever when it is engaged and so far I have restricted its use to priming strokes on the kick-start. Maybe it will come into its own on a frosty morning in December.
